crx problem....
Old Jan 13, 2004 | 07:43 PM
honda1998civic's Avatar
honda1998civic
Default crx problem....
i have a 91 crx hf and i just got my engine replaced but when i turn it on and drive my check engine light comes on.. then if i turn it off and turn it on again a different light comes on but no check engine light... its like everytime i turn it on again a different sensor comes on... what is the problem? any ideas?
Old Jan 14, 2004 | 05:49 AM
kd5dbl's Avatar
kd5dbl
Are you getting different blink codes from the ECU then? If so, which code(s) is it showing?
Old Jan 14, 2004 | 09:18 AM
Kai's Avatar
Kai
Rotorphile.
Exactly, time to check the codes.
Old Jan 14, 2004 | 01:03 PM
honda1998civic
i checked ecu but didnt do anything... the check engine light comes off after i turn off engine and start it back on but then it shows up after like 3 minuites... what could that be? the ecu is the little blue connector on passenge side kick panel correct?
Old Jan 14, 2004 | 02:10 PM
kd5dbl's Avatar
kd5dbl
Not sure about the '98, but on my '89 it is under the passenger side kick panel (floor actualy) and it has an LED on it that will begin to blink a code when the check engine light comes on. The next time the light comes on, pull over (leave the engine running) and take a look. It will give you some idea why the ECU decided to turn the check engine light on.
Old Jan 14, 2004 | 02:25 PM
Kai's Avatar
Kai
Rotorphile.
You don't need to wait for the check engine light to come on, the ECU will remember the codes until it is reset. Pull the kickpanel, read the blinky light, and tell us what numbers it gives you. If the CEL comes on the ECU will be blinking a code.
Old Jan 14, 2004 | 07:22 PM
honda1998civic
this is on my 91 crx hf... i see the blue connector and it doesnt blink any codes... can somthing be wrong with connector (ecu)? i put in paperclip and nothing... i did this on my 98 civic and it worked just fine at spitting out codes... i dont understand..
Old Jan 14, 2004 | 07:26 PM
Kai's Avatar
Kai
Rotorphile.
OK, blue connectors have nothing to do with anything.
Find the ECU. It is a gold coloured box with a few big plugs going into it, behind the passenger's kick panel. It will have a blinky light on top. Each time it blinks long, add ten. Each time it blinks short, add one. Example: long blink, short blink, short blink = 10 + 1 + 1 = code 12. It may show multiple codes.
Old Jan 14, 2004 | 07:43 PM
honda1998civic
ok.. thanks.. ill check ecu....
Old Jan 14, 2004 | 07:46 PM
kd5dbl's Avatar
kd5dbl
OK... visual aids time... pull back the carpet on the passenger side and look for the ECU LED...
File Type: jpg
