Is this vibrating normal?
Old Jan 13, 2004 | 12:36 PM
Hondaracer's Avatar
Hondaracer
Default Is this vibrating normal?
When i start my car and let it sit in morning to heat up i come out and its vibrating pretty violently. But when give it some gas it stops. Is this normal? It also vibrtea any time i let of gas or stop at light. Please help. If their is any way to fix if its normal or not please tell thx.
Old Jan 13, 2004 | 04:52 PM
WhiteRice's Avatar
WhiteRice
What's your RPMs?? I know sometimes mine will drop pretty low and it'll rattle from time to time. Is this it?
Old Jan 14, 2004 | 11:18 AM
Bogatyr's Avatar
Bogatyr
Hondaracer,
I've had Hondas in the past that would idle very roughly sometimes at idle. A tuneup would usually make things a whole lot smoother. When was your last one?
I'd also check out the condition of your motor mounts, just in case...
Bogatyr
Old Jan 14, 2004 | 12:19 PM
Hondaracer's Avatar
Hondaracer
Not sure the last time it had a tune up but it idles at 1 rpm.
Old Jan 14, 2004 | 02:36 PM
Magik's Avatar
Magik
"1" !!??
...or do you mean 100...or 1000...1 is wayyyy tooo low.
Jason
Old Jan 23, 2004 | 12:20 PM
Hondaracer's Avatar
Hondaracer
Sry havn't been on for a while but I meant 1000 rpms. Is that about right for it?
Old Jan 23, 2004 | 12:58 PM
Magik's Avatar
Magik
mine usually idles about 800-1000...so that sounds about right to me...
Jason
Old Jan 27, 2004 | 10:56 PM
Scrub91DX's Avatar
Scrub91DX
Un-Registered User
Mine Idles Pretty Rough right now and it idles at about 800 rpms but i know i have at least one bad motor mount, you should check the motor mounts out, and im sure that a tune up would help it.
Old Mar 11, 2004 | 09:52 PM
menappi's Avatar
menappi
man the same shit happens to me. i have some aftermarket mounts though, all bolted in pretty good, and it still vibrates like crazy, gradually increasing until 1.5k rpms, then after that it doesnt vibrate. ive checked and nothing is rubbing, but im thinking maybe i need to cut off my front tranny mount spot, cause i have an ls motor in it.
Old Mar 12, 2004 | 08:57 PM
mikeyg's Avatar
mikeyg
The label under the hood on my civic says 750 -+50RPM. I adjusted my timing and the idle speed and it still vibrates at lights, mainly when its in gear. I think its just one of those quirks with hondas.
