starter problems????
Old Jul 27, 2002 | 05:09 PM
pltnum_z's Avatar
pltnum_z
Default starter problems????
wussup everyone,
ive been havin trouble with my hatchback lately. the idle is low and it would stop on me when im at a complete stop. is this a starter problem or something else? thanks
Old Jul 27, 2002 | 06:22 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
Starter only does something when you are starting the car, once the car is turn on the starter is just dead weight. When a starter dies it doesn't crank at all, which doesn't seem to be your problem.
If idle is low and car dies I would say it might be a Distributor problem.
Old Jul 30, 2002 | 07:52 AM
excitid's Avatar
excitid
do a tune up and change your fuel filter. The bolts were a pain on mine but you will probably have fixed your problem by changing that.
Old Jul 30, 2002 | 09:04 AM
jaje's Avatar
jaje
HC Racer H5
your first check should be the idle...if your idle gets too low it could cause stalling...only thing you do is to turn the idle screw on the throttle body...it should be idling w/o a/c on and when the engine is warm around 500-600 rpm at the minimum
Old Jul 30, 2002 | 10:45 AM
WhiteRice's Avatar
WhiteRice
I'm having the EXACT same problem....FIRST...check to make sure your rotor isn't loose but still in good condition. If that's OK, then I'd say it's the ignition coil (ignitor). I'm replacing mine tonight after work. And hoperfully that'll fix the prob.
Also check to see if you're getting a spark from your plugs....if you're getting no spark, then do the above, if not, it could be a fuel flow problem....does your fuel pump turn on when you turn the key on??
We have the same symptoms, but maybe not the same problem.
littleguy_77
Minivan, SUV, & Truck
Nov 30, 2008 06:34 PM
mikeunreal
92+ Civic/EL & Del Sol
Oct 19, 2005 10:11 PM
speedshifter101
CRX & Pre 92 Civic
4
Jan 15, 2005 05:30 AM
blackstar
Accord
15
Oct 30, 2004 01:04 PM
sick79
CRX & Pre 92 Civic
Jan 13, 2004 10:53 PM
