97 2.5 TL crankshaft pulley
Old Nov 11, 2006 | 04:42 PM
v-8 volvo's Avatar
v-8 volvo
Default 97 2.5 TL crankshaft pulley
I was recently doing the timing belt job on my girlfriend's 97 2.5 and noticed a problem with the crank pulley. Apparently the bond between the outer sheave(the one that drives the A/C compressor) separated from the rubber insert that provides the dampening. Has anybody seen this before? The car has 98K on the odometer. Acura gets $300 for the pulley. Does anybody have a used one out there?
Thanks,
Mike
Old Feb 21, 2008 | 10:26 AM
binhnguyen00's Avatar
binhnguyen00
Electronic Stuff
hi mike i bought my crank shaft pulley at https://www.rockauto.com
Old Mar 17, 2008 | 04:28 PM
Jimboacura's Avatar
Jimboacura
I am trying to replace the harmonic balancer/crankshaft pulleys on a 96 Acura 2.5 TL. Does anyone know if there is a special tool for holding the pulley still while loosening the bolt? Thanks
Old Mar 25, 2008 | 07:02 PM
aspen007's Avatar
aspen007
Yes, there's a crankshaft pulley holder made especially for honda and acura. You can find one on ebay for $40 and up.
The holder inserts into the pulley and has a hole in the center that allows you to insert a socket to grab the bolt holding on the pulley.
