Replacement power antenna
Old Oct 25, 2005 | 08:14 PM
92vigor's Avatar
92vigor
Default Replacement power antenna
Has anyone tried to replace a power antenna with one that you see on Ebay, selling for around $25.00? The one on my Vigor has packed it in and
the Dealer wants about $250.00 to replace it. Hard to justify that coin.
Do they come with the wiring harness or do you have to wire it in yourself.
Thanks for the input.
Old Oct 26, 2005 | 06:46 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
the wiring would have to be spliced in if a "aftermarket" antenna is used
Does your antenna still try to work, or is it just dead all together? If it still attempts to work, you should be able to replace just the mast.
Old Nov 10, 2005 | 11:37 AM
toplineauto's Avatar
toplineauto
I bought one from a Honda site and installed it. It was only about $20-30 bucks. I may have that section of the service manual.
