replacing brake light switch on 92 vigor
Old Mar 8, 2004 | 10:15 AM
jonschatz's Avatar
jonschatz
Default replacing brake light switch on 92 vigor
I've determined that I have a bad brake light switch. Tail lights blinkers everything work just no brake lights. Also the cruise control does not work which someone else on another forum said happened to them with this problem. Does anyone know exactly where the switch is. I'm assuming its somewhere between the steering column and the break pedal. Any help is appreciated.
Thanks!
Old Mar 9, 2004 | 08:58 AM
AcuraFanatic's Avatar
AcuraFanatic
I'm not sure, but will get back to you on that!
Old Mar 10, 2004 | 08:02 PM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
It should be right behind the brake pedal arm, it's got a threaded base that is screwed into the pedal arm and a nut that is tightened to hold it's adjustment. the switch is closed with the pedal all the way forward, when you push in the pedal the switch's plunger opens and your brake lights come on. My g/f's just went out last week(hmm)
and I picked one up from HAP for 10 bucks and it works fine. She has a 93 accord though. Honda's retail price was around 53 dollars. It might just be out of adjustment
You can see the plunger come out when you push the pedal in if you look under the pedals. If it's out of adjustment it will give you the same symtoms.
Hatchy
Showroom
3
Jul 31, 2002 09:34 PM
Buddy
Jul 8, 2002 03:27 PM
Outxider
92+ Civic/EL & Del Sol
4
Jun 24, 2002 06:44 AM
ElectronBlueGSR
12
Jun 21, 2002 07:58 AM
