which speakers, where?
Old Aug 13, 2003 | 02:13 PM
ISP James's Avatar
ISP James
DAMIMRED
Default which speakers, where?
JL Audio XR-650-CS (component set)
JL Audio VR-650-CX (coaxial)
1994 Integra without tweeter mounts on the door. dont know which set would sound better in the front, which in the rear.
and where would be a good place to mount the tweeters?
Old Aug 13, 2003 | 03:48 PM
ISP James's Avatar
ISP James
DAMIMRED
and one more question, my car came with a 200 watt Optimus amp... not hooked to anything is that 200 peak or RMS? my speakers are 75 watt constant power so i wondered if i could run a pair with it
Old Aug 13, 2003 | 04:00 PM
97teg's Avatar
97teg
xr's are the better set im pretty sure. They are the higher line i would put the components in the front. If you really don't want to drill new holes for the tweets you can mount them right infront of the mid in the door using a piece of metal. Just make sure the mid doesn't hit it when the speaker begins to move a lot and the tweeter clears the door.
The amp should say if its rms or peak. I have a suspicion its probably peak but i dunno. Itll work but I personally would sell it and invest in a better quality amp. Its still better than nothing though.
Old Aug 13, 2003 | 05:53 PM
ISP James's Avatar
ISP James
DAMIMRED
the XR's are the better set. i was hopin to avoid drillin so ill try mounting them on the speaker grill, good idea.
i cant find anything on the amp that says rms or peak but ill give it a shot and hope it doesnt ruin anything
id sell it and reinvest but i have other priorities right now, and like you say, it's better than nothing.
thanks!
