Setting up a booty call alarm
Old Jul 16, 2002 | 03:39 PM
JJJ784's Avatar
JJJ784
No Soup For You!
cool... now let the booty calls begin!!!! hahaha
Old Jul 17, 2002 | 03:51 PM
integramodder's Avatar
integramodder
so LjN_728, are you looking for a way for your system to go into panic mode (alarms blaring and all?)
or just a way that someone can physically come upto your car, press a button, and temporarily make the alarm system sound to get your attention...?
Old Jul 17, 2002 | 03:57 PM
LjN_728's Avatar
LjN_728
Well the ONLY real purpose of the booty call alarm is to get chick's attention cuz would u really wanna honk ur horn at them? haha i hope not...scare the shiz out of them!! But some people like it because it's an option that cost close to nothing and it gives them another horn to play with...i guess?
Old Jul 21, 2002 | 09:21 PM
JJJ784's Avatar
JJJ784
No Soup For You!
i just wired up my booty call. let the fun begin!! woohoo.. hahahahaaa
Old Nov 6, 2002 | 10:53 PM
RST531's Avatar
RST531
so thats all that is needed (a long speaker wire and a push button of my choice) so i just find the pos wire that gos to the alarm and the splice it near the fuse box and and put my wire in that place with the button in between.and then all the honey will be all over me , lol. so noone has had any problems with this so far?
Old Nov 6, 2002 | 11:22 PM
JJJ784's Avatar
JJJ784
No Soup For You!
no problems at all. i use it almost daily. hahahaa.. :P
Old Nov 7, 2002 | 12:16 AM
LjN_728's Avatar
LjN_728
the only possible prob that you can run into is the push button. That's because after so much wear and tear, it just malfunctions. But don't worry because the pack they sell at Radio Shack comes in a pack of 5. wow i'm so surprised so many peeps read this thread. I guess it's just the title "Booty Call".
Old Nov 7, 2002 | 09:04 AM
RST531's Avatar
RST531
so i just need to cut the wire close to the fuse box right, not close to the alarm?
Old Nov 7, 2002 | 09:06 AM
b18cya's Avatar
b18cya
uh, no u suck
hahaha, he's gonna try to pull people over at night!!
Old Nov 7, 2002 | 11:48 PM
LjN_728's Avatar
LjN_728
No you don't need to cut any wires close to the fuse box. You know where the "brain" of the alarm is? It's located right under the dash. It's a small device that has all the wires connected into. Now look for a solid yellow wire. That's your continous (+) wire. Now you have to remember to use a long enough wire that will reach from that yellow cable to where ever spot you want the push button and out to where the siren is. I'd give about a good 10 ft.
So tap the new wire to the (+) yellow wire, and then connect it to the switch. Using the output part of the switch, run the wire thru the firewall and connect it to the red (+) wire of the siren.
You're all done! Have fun whistling at those hunnies!
krazyymunkee
92+ Civic/EL & Del Sol
11
Oct 4, 2003 03:24 PM
digitech
Do It Yourself
2
Jul 6, 2003 10:14 PM
