ohm question for speakers
Originally posted by Josher
And the specs on paper on paper are usually right. I doubt a speaker company would lie about the volume of their speakers. They will however, run their tests with cars at 14V and at beautiful temperatures and atmospheric pressures. Of course the specs given by manufacturers are ideal, not lies. You just have to know how they find their numbers.
Specs are rarely accurate IMO. Some you trust others you don't (i.e. that legacy "2000W" amp).
Originally posted by azmi222
Additionally you will cut the life of your amp if you run it at two ohms. A decrease in impedence causes an increase in current draw and therefore creates more heat. If you have a high quality amp and must run the fifth channel in 2 ohm buy what is called a "Dual Voice Coil" or DVC sub and run the channels in parallel. :naughty:
Also, the amp doesn't care what cofiguration the sub is or how many subs there are - the only thing it sees is a resistance, and adapts accordingly.
What I meant to say was the terminals on the speaker in parallel. Most amps have a thermal protection circuit that will shut the amp off if a low impedence load is presented. You are increasing current and therefore increasing heat. Most five channel amps cannot take a DVC sub on the fifth channel since the channel usually shares internal components with at least two of the other channels.
Additionally speaker manufacturers lie all the time. There is no regulation to what they can publish. Do you really believe that the average radio made by Sony is 52 x 4. They are trying to put the biggest and best numbers that they can on the box.
On paper the Pioneer speakers far exceed the capabilities of the type r, but your ears tell you differently. I think the type r alpines are so so, but they are better than pioneers. Tough to justify for the $$$.
Originally posted by rcurley55
Take a look at headunit amplifier specs, then take a look at the statement above....Care to revise it?
Whatever I'm supposed to see, I'm not seeing it. Are you going after the 14V, where manufacturers put 14.4 V, but 11 - 16V is allowable?
Or is it the fact that the Maximum Power output is achieved at the maximum voltage?
For example...an alpine head claims 60W x 4. There's no way in hell that that amp in that head puts out anything near that kind of power unless the mfg. totally twists the testing procedure.
Have you ever looked at those computer speakers out there that cost $16, yet they claim 400W or something like that? Same thing....
That's what I meant....manufacturers are very tricky now-a-days. The naming of most amplifiers are also quite deceiving. It's all a marketing thing.
this thread seems to be a good one i am enjoying it.
its amazing to see all the mis-information out there
basically i agree with curley 55 deck power sucks some are better than others but if you want to here all the music the way it was intended get a good amp with good speakers(speaker opinions as we see are at the least varied lol)
some things i look for in an amp
the manufacturer ie: quality control, warranty, yrs in bussiness
what imput voltage the are basing the output in RMS
THD less than 0.5% at rated power @ 2ohms. BE SURE ITS FROM 20-20K HZ anyting less is B.S.
damping > 100 db
ihf dynamic headroom +3db or better most mfg. dont disclose this
signal to noise >100db
separation >90db
build quality/ what country of origin
these are the basics for me. there is more to look at, like if it has crossovers, bass control, etc.
damping > 100 db
separation >90db
First I "defy the laws of physics" and now you agree with me.....
Country of origin has little to do with inherent quality. The design is more important then where the machine putting parts on a board is located at. So long as the specs/tolerances of a product are well defined....it can be built almost anywhere with today's global economy and no one would be the wiser...
Just an FYI, an amp doesn't perceive any difference between a DVC or an SVC sub - so long as the final load that is presented is the same.
