Remote Start! Pls. Help!
Old Jun 16, 2003 | 03:59 AM
ziljin's Avatar
ziljin
Default Remote Start! Pls. Help!
Hi everyone,
I'm trying to intsall a crimestopper remote starter in a '93 si... I'm having problems getting the car to stay on. It'll start for like 3 seconds then shut off... I tried diff. tach. sources, tried timed crank, tach ref and tachless. Nothing is working. I'm thinking it's my wiring.would I need a secone ign. relay? Any help would be GREATLY appreciated! Thanks a bunch, Jeff
Old Jun 23, 2003 | 03:21 PM
kenn22civic01's Avatar
kenn22civic01
The engine stopped after 3 secs because your unit can not detect whether the engine has started or not so it redo the cycle. I solve this problem is by using sparkplug sense ( review your unit's manual for this feature.) Basically you would wrap a wire around the sparkplug wires. When the engine starts, the current running in the sparkplug wire will induce a voltage at your loop wire and "alert" the unit. Hope this helps
Old Jun 25, 2003 | 02:45 PM
jfiedler's Avatar
jfiedler
Junior Member w/Fries
yeah same problem here, i tried every method possible to get the tach pickup to work...and never could. i just wrapped a wire around one of the plug wires right at the distributor...worked perfectly first try.
make sure you set the crimestopper alarm brain to sense via sparksense, not tach.
