buying amp and subs
Hey first of all, this is my first post and i'd like to say this whole website is AWESOME! I've already learned so much.
Anyways, I'm planning on getting subs for my 96 2 door RS integra, and I was wondering if this amp and these subs would go well with each other:
Lanzar Viberant series 1400W-
4 x 175 Watts RMS at 4 Ohms
4 x 350 Watts Max at 4 Ohms
2 x 700 Watts Max at 4 Ohms Bridged
4 x 300 Watts at 2 Ohms
Electronic Crossover Network
Bass Boost Circuit
Bridgeable at 4 Ohms
2 Ohms Stereo Stable
Tri-Mode Capable
Gold RCA Inputs
Line Outs For CH1/CH2/CH3/CH4 channels.
Power & Protection LED Indicators
Advanced Protection Circuitry
Soft Turn On/Off
Remote Control Bass Booster
Frequency Response: 15 Hz - 35 kHz
S/N ratio: 90dB
Dimensions: 11.5"W x 2.3"H x 17"L
2 Pyramid PW1265US-
Diameter 12.125”
Imped 4 Ohms
Voice Coil 2” Hi-Temp Kapton
SPL @ 1W/1M 90dB
Freq. Resp. 28Hz-2.5kHz
Magnet 60 oz. B&V
Mounting Depth 4.75”
Power RMS 350
Power Peak 700
These are all the specs I have.
Any responses will be useful:: thanks
Bass Boost Circuit
Tri-Mode Capable
Gold RCA Inputs
Soft Turn On/Off
S/N ratio: 90dB
2 Pyramid PW1265US-
Diameter 12.125”
Imped 4 Ohms
SPL @ 1W/1M 90dB
Magnet 60 oz. B&V
Power RMS 350
Power Peak 700
ugh pyramid... a RF punch sub will give you more low end than that sub. The amp sounds decent enough though.Give it a whirl, and tell us how it sounds, I'd recommend entry level subs from infinity, alpine, RF, kenwood, ... and for a little more money perhaps a fantastic Image Dynamics IDQ or Shiva.
I dont know what your budget is and what about the rest of your sound system... is this just an add-on to your stock outfit?
Well, from what I've heard, the fastest cheapest upgrade to a sound system is the subs, so that's why I'm doing it, I plan on getting other new speakers, plus adding two 6x9's to the rear deck.
(and just for anyone's info, the only thing I've done to the audio system is got an alpine deck 7872)
And as far as those subs go, I know they're not great but do you think it's a good deal if I'm getting them for 28 bucks plus s/h.
Might as well ask about the amp too then, I'm getting it for 150
I've been a long time proponent of the theory that for most consumers, while you don't need to buy the upper eschelon of products, you also should stay away from the low end too. These subs are in the basement.
Think about getting one good driver from a well respected mfg. - look at the "off" brands like eDesigns or Adire.
I guess what I'm saying is that it doesn't make sense to spend your money just so you can have two 12's...just to have them. Save some money and do it right the first time.
If you want REAL power for little $$$ - go get a JBL BP600.1 from ikesound.com.
That's my honest opinion.
Yeah I argee wait for the money to do it right. If you really can only afford 75$ then wait imo its not worth it. Wait till you have enough money to do it right. The first time otherwise its a wasted 75$. Give a reasonble budget to work with.
yeah man theres a reason those things are so cheap..hold off and youll be alot happier in the long run..
good luck!
o yeah the lanzar VIBE series amps arent bad but i wouldnt go with the viberant..there is a difference. also like curley said, check out jbl amps for good, cheap power and eD for awesome, affordable drivers.
good luck!
