powering a JL w0
i just got a great deal from a friend for a JL w0 15" and a crossfire amp.. i went on the site and rms for sub is 150.. and the amp i believe is the 50.2.. wut's the best way to wire it for most bang.. or should i just get a new amp and sell the crossfire one..
Originally posted by WiLL
post the model of the amp and specs for the subs.
h: But since the sub is 150 watts rms, then try and give it that kind of power. A little more would be good as well....
the amp model is TEK502..
2 channels bridgable
50 w x 2 at 4ohm
95 w x 2 at 2ohm
180 w x 1 at 4ohm bridged mono
the sub JL audio 15" W0
19.2 Hz 4 ohm
Qts 0.389
Qes 0.403
Qms 11.29
18.6 Hz 8 ohm
Qts 0.405
Qes 0.420
Qms 11.29
150 watt
thanks
50 w x 2 at 4ohm
95 w x 2 at 2ohm
19.2 Hz 4 ohm
Qts 0.389
Qes 0.403
Qms 11.29
18.6 Hz 8 ohm
Qts 0.405
Qes 0.420
Qms 11.29
150 watt
thanks
TheOtherDave™
Automotive News & Rumors
Aug 28, 2008 04:20 PM
