sub / amp wiring.
Old May 6, 2003 | 01:47 PM
epoxy's Avatar
epoxy
Regulator
alright... i'm only going to get one of those amps. Do I still need 0 Guage wire or can i use 4? (ground / power)
I want it to sound good to it's full potential!
Old May 6, 2003 | 01:51 PM
rcurley55's Avatar
rcurley55
Look up a few posts ^^^^
Originally posted by rcurley55
Now IF you dropped to running these at 4 ohm mono, or one amp at 2 ohm, that's a total draw of approximately 150A....you can squeak by with 4ga, but I would still go with 0/1 ga to be safe.
Old May 8, 2003 | 10:18 AM
Stunna's Avatar
Stunna
try www.knuconceptz.com
Old Oct 1, 2005 | 09:47 PM
set_civic's Avatar
set_civic
i actually do custom installs and compete. i hold three 1st place state and regional records and one 2nd place state record. 0 gauge (alt wire ) wire is the best and if you can get 2 alt that would be better. the distance from the battery to the amp determines how big a wire should be. i have four strands of alt wire running from my battery to my amps. i have a 200 watt amp, a 400 watt amp, a 600 watt amp, and a 1800 watt amp. alt wire is awsome. i use it on pretty much everything. another way to tell what size to use is how big of wire is the amp made to accept. if its only made for 4 gauge then use that but with the amount of power your lookin at id run alt wire to a distribution block and 4 gauge from that. look on www.partsexpress.com. they sell alt wire for like $2.19 a foot. its $54 for 25 feet. invest in it.
Old Oct 1, 2005 | 09:50 PM
set_civic's Avatar
set_civic
another thing. capacitors are very over rated in all actuallity they only cover about 300 watts with a 1 farad. im not jokin about any off this. email me if you really wanna talk about the technical tips i caqn give you. these are pictures of my 2 cars. i now have many more trophies than whats pictured
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
