Wiring Techniques for DVC
lol shit well a wire already fell off.. why did i use gator clips?!? ARGH!!! and my cap isn't working.. could it be because i had EVERYTHING plugged in before i reconnected my power wire to my battery? is that why it didn't charge?
huh? you mean touch the negative and positive post together?
i dont think so.
the cap should have came with a chip which you would use to charge it up before use. you hook the chip up to the negative and positive post, then hook it up to the battery post and ground it.
when its done, a LED will go off.
i dont think so.
ok first off they will constantly lose charge if you take the power source away.. this is not the issue. it was off for all of maybe 30 minutes. Again i just need know how to reset the damn thing so it'll act as a cap.. i think it was just pretending to be a battery for awhile and now just sits there letting current go through rather than collecting it.
