Mutli-Amp Setup
Old Feb 19, 2003 | 06:35 PM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
Default Mutli-Amp Setup
Ok, I am planning on having 3 12w3v2 subs and was thinking 2 1000 watt peak amps to go with em but figured didn't need that much power. What would yall suggest amp wise? And I'm no familiar with the running of mutli-amps and would appreciate it if someone could give me the lowdown on hooking it all up, appreciate it in advance!
~Green Civic EX
Old Feb 19, 2003 | 08:25 PM
rcurley55's Avatar
rcurley55
Default Re: Mutli-Amp Setup
~Green Civic EX
Two problems here...first, you shouldn't run two amps to 3 subs, unless the amps are strappable.
I guess you could wire one coil from each of the subs to one amp, then the second set of 3 coils to the other amp. But that's one hell of a hassle...
If you are looking at amps, I highly recommend that you entirely disregard any spec with the word "peak" next to it....generally, those numbers are fairly usless. Take a look at the RMS numbers.
I'm willing to bet that you will find a single 1000W RMS amp to be more then capable and easier to mount, setup and wire then a pair of smaller amps (this route is typically cheaper too!)
Old Feb 20, 2003 | 12:10 PM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
thanks man, appreciate it....have any 1000 rms amps in mind that don't cost out of the ass?
~Green Civic EX
Old Feb 20, 2003 | 12:12 PM
rcurley55's Avatar
rcurley55
Define the above term with a number....
Old Feb 20, 2003 | 01:41 PM
MikesCommuter's Avatar
MikesCommuter
As the ACCORD TURNS!
JBL BP1200 will do ~1300 watts @ 2 or 1 ohms.
only $250.00 + shipping from www.ikesound.com
Old Feb 20, 2003 | 06:58 PM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
My price range is about $200-$350. ANd i need a multi-channel amp cause i'm gonna have it hooked up to one 12w3v2 for a while but then i'm getting two more so I'll need an amp that will be able to push three 12w3v2's. ANy more suggestions, bring em please!
~Green Civic EX
Old Feb 20, 2003 | 08:09 PM
97teg's Avatar
97teg
200- 350 isn't much if your looking for a good amp to push 1,000 w to them. You might find some good ones for cheap but im willing to bet you won't get a factory warrenty so it may be a bit risky. If you feel its worth it then go for it. I would figure about 500 for an good amp with that much power but thats just imo.
Old Feb 23, 2003 | 03:36 PM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
Ok, I was wondering if there was more than one variation of the JBL 300.1 amp cause my friend has one powering two JL Audio 12W3's in a vt box and it sounds incredibly well. I looked up the specs on the amp and just thought it weird such a small amp could make two 12's sound so good. If you can answer, thanks. I'm thinking about getting it for my sub.
~Green Civic EX
Old Feb 23, 2003 | 07:02 PM
rcurley55's Avatar
rcurley55
JBL makes 4 amps in that line if I remember correctly.
150.1
300.1
600.1
1200.1
Each make the power equivalent to their model number at either a 1 or 2 ohm mono load.
I'd run either the 600 or the 1200 - both are cheap and capable
