a simple amp question
Old Jan 25, 2009 | 06:06 PM
russianpsyco's Avatar
russianpsyco
Default a simple amp question
I have a 5 channel theater amp and I have a front and rear center speaker. Could anything go wrong if I connect both speakers to the center channel on the amp? If it makes a difference, the amp is 60Wx5 RMS.
Thanks
Old Jan 25, 2009 | 11:14 PM
b00gers's Avatar
b00gers
If you connect both positives together and both negatives together, you will lower the impedance. By doing so, the amp will run hotter. It will either continue to run hot or go into protective mode and shut off.
Old Jan 26, 2009 | 01:05 PM
DakarM's Avatar
DakarM
yeah i don't see the point of running both sets of wires to the same speaker. also most movies aren't coded with rear center channel so it would be best to just not hook it up if you don't have a spare speaker.
'00 Dakar Bus CRS Edition
LCD Squad #0001
Originally Posted by WiLL
Old Jan 31, 2009 | 02:37 PM
russianpsyco
I have another question then. Right now I have the rear center speaker hooked up to my sub amp so it puts out nothing but bass. Is there a way I can hook it up to get music out of it?
Old Feb 1, 2009 | 08:39 AM
b00gers's Avatar
b00gers
You are getting nothing but bass because the amp has a low pass filter on it. That means that only the low frequencies are being passed to the speaker. What amp is this? You might have an option to change the filter with a switch...
