need help horn on 2000 civic si is not working?
Old Jan 13, 2009 | 05:11 PM
civic_si's Avatar
civic_si
Default need help horn on 2000 civic si is not working?
The horn on my 2000 CIVIC SI is not working, and I try to find the horn wire, but can't seen to find it, anybody have a wire diagram for a 2000 civic si?
Old Jan 14, 2009 | 05:03 AM
Tedmond's Avatar
Tedmond
Horn GRAY (-) STEERING COLUMN OR GRN PLUG BEHIND RADIO
to test if the horn is still working, splice into the horn wire, connect a wire to it and the end of that wire to ground. If the horn is still good, it should still honk. if not then horn or relay is gone.
Old Jan 14, 2009 | 10:38 AM
civic_si's Avatar
civic_si
so behind the radio is the green plug and which wire is the horn wire? So what you saying is that connect a wire on the green horn wire to ground? Also, where is the relay located at?
Old Jan 14, 2009 | 05:02 PM
civic_si's Avatar
civic_si
There is a green hardness on the left next to the radio on a 2000 CIVIC SI, anybody know what that hardness connected to?
Old Jan 14, 2009 | 06:47 PM
Tedmond's Avatar
Tedmond
uhhh....its actaully a GRAY wire. Its located at the steering collum and behind the radio. I suggest you go to the steering collumn since its easier to get to.
Old Jan 15, 2009 | 11:17 AM
civic_si's Avatar
civic_si
Solve the problem! It's the horn that is not working. Thanks for your help....Also, I have a green hardness on the right side of the steering wheel, you know what that green hardness connect to on a 2000 CIVIC SI?
