installing sub into box...
Old Oct 26, 2002 | 11:17 PM
Chiuey's Avatar
Chiuey
Default installing sub into box...
I was just wondering, does it matter if the screws that attach the sub to the box go thru the front panel to the other side, or should it stop before it reaches thru the wood? the box is about 1 1/2 inches. Will it affect the sound?
Old Oct 27, 2002 | 05:18 AM
smokedogg's Avatar
smokedogg
it shouldnt affect the sound at all; mine go all the way through...if your that worried about it, go grab some shorter screws
Old Oct 27, 2002 | 09:19 AM
b00gers's Avatar
b00gers
Default Re: installing sub into box...
you mean the screw is 1.5", or is your box made of 1.5" material?
itll be fine if the scew goes through.
Old Oct 27, 2002 | 06:05 PM
seth90dx's Avatar
seth90dx
If the box is 1.5" and you used mdf, that might not be healthy for the subs! But if the skrews go through it wont do crap! If you still trip on it like me, add the length of the skrew that pokes through the wood times however many skrews you have and build a box (should be about 0.3" inches bigger! LMAO
