car amp question
Old Feb 4, 2008 | 04:53 AM
OblivionLord's Avatar
OblivionLord
Default car amp question
Is this calculation correct for a car amp having total output for a medium amount of 13v considering you arent going to always get 12v to the amp nor 14v....so... 13v * 35a(fuse) = 455w total power and at 70% efficentcy would then be 318w.
Old Feb 4, 2008 | 08:45 AM
b00gers's Avatar
b00gers
MAX power
Old Feb 4, 2008 | 03:06 PM
OblivionLord
318w max wattage. How do you do the calc for RMS?
Old Feb 4, 2008 | 06:56 PM
Tedmond's Avatar
Tedmond
divide by 2, then by the number of channels your amp has.
Old Feb 5, 2008 | 04:12 AM
OblivionLord
Is it advisable to judge the output wattage by the fuse used on the amp itself since anyone can put any fuse with a high amp number just to say it can do high wattage?
Also don't amps have a different output current outside of what passes through the fuse first? In which case the total watts can't be judged by using the amps off the fuse.
Old Feb 6, 2008 | 11:41 AM
OblivionLord
noone?
Old Feb 6, 2008 | 04:19 PM
Tedmond's Avatar
Tedmond
well if some1 was really snake and put in bigger fuses to say the amp pushed more that what it could do, i wouldnt even use the amp. thats a fire hazard. also amps dont put "current" out to the speaker terminals. if you know what amp you have go to the website and download the specs for it. it will tell you exactly how much power RMS you can get out of it.
Old Feb 7, 2008 | 06:40 PM
OblivionLord
what determines how large the fuse is outside of specs? Also the current changes from transistors inside.
