system installation
Old Dec 14, 2007 | 02:00 PM
maxipereyra15's Avatar
maxipereyra15
Default system installation
i just installed my sound system, with a capacitator, amp, and sub, i hooked everything up and, my amp is not working, it barely moves, i messed around with the gain, and frequency and it starts making weird noises, my stereo is different from my last one it has one rca wire that says subwoofer, and then it has the rca outputs, which one do i use i have to rca's coming from the sub?
Old Dec 14, 2007 | 06:04 PM
sqsi's Avatar
sqsi
you use the sub out and you may need to turn the subwoofer control on on the headunit, check the manual or post what your headunit is
Old Dec 15, 2007 | 08:31 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
I'll bet it's a Dual in-dash.
Is your amp powering on?
What amp is it? I need the model and brand.
Model and brand of head unit?
Model and brand of subs?
How is it wired?
Did you run a remote turn-on wire?
Old Jan 11, 2008 | 08:40 AM
pan7285's Avatar
pan7285
Its possible that the RCA marked "Sub" will be a mono output (as you don't need left and right channel for pure bass tones). The other RCA outputs will be for normal speakers inside the car (should you decide to run them off a seperate amp).
With the stereo turned off, check that the amp is getting 12v on a volt meter. When you turn the stereo on, check it again... it should remain at 12v... if it drops to 10v, its possibly and earth leakage issue and you'll need to check you cabling to make sure everythings secure and you have a good earth.
hope this helps
