CRX ignition wires
Old Aug 25, 2007 | 04:27 PM
vigalantyvillan's Avatar
vigalantyvillan
Emo hunting Crx driver!
Default CRX ignition wires
I was trying to install a killswitch to my ignition but wasnt sure which wire was the hot wire when fully engaging the key. I dont have a battery to voltage test it so i was just curious if anyone knew the color of the wire or an easier way to cut power to anyone trying to hijack my shit.
Old Aug 25, 2007 | 04:58 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
Model year of the vehicle would be nice.
Old Oct 28, 2007 | 02:37 PM
vigalantyvillan
91 honda crx si
Old Oct 29, 2007 | 08:20 AM
totalimmortal
MalleusMaleficarum
Lemme look it up when I get home. Every Honda has had the same color ignition wires for the past million or so years. BUTTTT, you should get a multimeter anyways and test before doing anything.
Old Oct 29, 2007 | 06:14 PM
vigalantyvillan
eewwh true its just that im in the process of rebuilding the whole car so the power isnt hooked up. i still need to figure out the clutch/transmission problem and find a starter
Old Nov 1, 2007 | 02:35 PM
Tedmond's Avatar
Tedmond
hey man, i got you covered.
12 volt constant White/black @ ignition harness
Starter Black/White @ ignition harness
Ignition Black/Yellow @ ignition harness
Accessory Yellow @ ignition harness
1) Cut starter wire in half (Black/White), leave some wire to work with.
2) Connect (-) when armed from Remote start or alarm to relay Terminal 85
3) Connect Starter wire (MOTOR SIDE - going to car) AND Remote Start WIRE together if available. Wire to relay Terminal 87a
4) Connect Starter Key Side (ignition cylinder) wire to relay Terminal 30
5) Connect Jumper Cable from relay Terminal 86 to relay Terminal 30
6) Place Diode across relay Terminal 85 and 86 (diode with white Line to Terminal 85)
Old Nov 1, 2007 | 07:23 PM
vigalantyvillan
badass bro thanks
Old Nov 3, 2007 | 03:04 PM
Tedmond's Avatar
Tedmond
hey vigalent, if you need any help on wire location for alarm or sound systems i got you covered. if you plan to do a remote start, send me a pm, ill be glad to help you and anyone out
Old Sep 4, 2010 | 11:09 AM
D16z6 Sol's Avatar
D16z6 Sol
Default Hey
Hey, I am planing to do a push button start in my 1993 Honda delSol Si. I look up some other forms, and got some good info, but I cant find the harness where I need to splice the wires. here is the info i found. please help. i cant find this harness, even with my service manual.
http://www.8thcivic.com/forums/elect...diagram-4.html
