getting through the firewall
Old Mar 26, 2007 | 12:14 AM
russianpsyco's Avatar
russianpsyco
Default getting through the firewall
what would be the easiest way to get through the firewall on a 93 prelude with an 8 gauge wire? will I have to drill a new hole? everything I tried so far doesnt really work out.
Old Mar 26, 2007 | 07:17 AM
dleccord's Avatar
dleccord
8 gauge should be a breeze. You're not trying hard enough
Old Mar 26, 2007 | 10:48 AM
akeura369's Avatar
akeura369
just find a grommet somewhere...theres gotta be one with nothing in it that u can just pop out or rip through, or if theres one with wires already through it, just shuv the shit through
Old Mar 26, 2007 | 07:50 PM
rcurley55's Avatar
rcurley55
find the ecu, trace it back to the firewall - that grommet will easily accept an 8 ga wire - I got a 0/1 through on my old civic
Old Mar 27, 2007 | 03:56 AM
InfoAudio01's Avatar
InfoAudio01
if it is an automatic then you can drill through the clutch-plate area on the firewall and use a plastic in the hole you drilled to keep the sharp edges from cutting into the power wire...
unless of coarse you can find a grommet to use.
