cooling fans
Old Oct 7, 2002 | 01:18 PM
rcurley55's Avatar
rcurley55
Originally posted by WiLL
ok that shoebox example and clarification of the inlet hole in the box made more sense to me.
Cool...I thought that I would have to start breaking out Bernoulli's Equation!!! 4 years at engineering school comes in handy sometimes!!
Old Oct 7, 2002 | 02:02 PM
mobius's Avatar
mobius
Originally posted by rcurley55
What are the dimensions on the amp rack? What size fans?
Gotta have more information then that.
the enclosure will be something like 3- 3.5 feet wide by 1.5-2 feet deep by 6-8" high.
I remember (sort of) Bernoulli's eq. from physics in high school....like 9 years ago.....sheesh....has it been that long!
Old Oct 7, 2002 | 05:03 PM
Bass Mechanic's Avatar
Bass Mechanic
Rcurley55 is on the right track i also use 2 fans in my power mouse boxes. but i blow air into the rack. the hot air rises so it is better to aid the air moving up and out of the rack rather than try to pull it down and the opposite way the air wants to naturally flow. i also use 2 fans. they are only 2 3/8" fans but i did a lot of searching and found them to be rated at 18cfm each. for a small fan that is really good. they also have 100% ball bearing and brushless motors so they last forever.
i use mostly class d amps for the subs so they dont get that hot. all you need is a slight breeze to keep them cool.
