amp problem
Old Nov 27, 2006 | 01:38 PM
Tyler88's Avatar
Tyler88
sinking steps rising eyes
Default amp problem
So i got my RF t500.2 and my RE XXX. I move it all to my friends car to hear how it sounded in there and then move it back to my car. It doesn't work. The amp doesn't even turn on. I check all the wiring and try again. still doesn't work. Disconnect the speaker wires from the sub and it still doesn't work. I check the ground and positive on both ends and they were fine. The remote wire is also fine. I hooked the amp up in my friends car and it worked. Right now i'm checking the inside of the sub box to check the wiring. The amp should still turn on though without output though right? any ideas?
Old Nov 27, 2006 | 03:43 PM
tommyhcky13's Avatar
tommyhcky13
check fuses
Old Nov 27, 2006 | 07:21 PM
Tyler88's Avatar
Tyler88
Originally Posted by tommyhcky13
check fuses
Like the one right before the connection to the battery post?
Old Nov 27, 2006 | 09:20 PM
Misa's Avatar
Misa
Pic Whore
yes.
Old Nov 28, 2006 | 11:48 AM
tommyhcky13
and the ones on the amp
Old Nov 28, 2006 | 06:29 PM
burnrubber's Avatar
burnrubber
Nucking Futs
and check to see if the remote is sending power, not just that its connected
Old Dec 2, 2006 | 11:36 AM
Tyler88's Avatar
Tyler88
it was the fuse on the power wire
thank you all
Old Dec 2, 2006 | 04:33 PM
tommyhcky13
theres a reason the fuse blew. check all of your wiring make sure anothing is being grounded out because if it is your car could burst into flames. did you run the power wire through the door???
