Need more power?
Old Sep 27, 2002 | 10:42 PM
seth90dx's Avatar
seth90dx
Default Need more power?
Well my subs hit great untill half volume! then they start POPING! Ive got 2 12W3V2's being pushed by a 500/1 monoblock. As most of you already know!
Old Sep 27, 2002 | 10:52 PM
b00gers's Avatar
b00gers
thats enough power. did you set the gains and other settings correctly? is the box made correctly to spec?
Old Sep 27, 2002 | 10:56 PM
seth90dx's Avatar
seth90dx
YA, EVERTHING IS IN ORDER! I GOT EVERTHING I SHOULD NEED! Maybe I need to rewire the subs? I got them both set at 2ohms and my amp has a recomended load of 1.5 ohms max... So Im basicaly tryin to get 1.0 ohms out of the amp... You think that could be the problem?
Old Sep 27, 2002 | 11:23 PM
b00gers's Avatar
b00gers
why dont you wire them to a final 2OHM....dont those JL give the same power from 4, 2, 1 OHM?
just wire it series on each sub, then //.
Old Sep 28, 2002 | 08:15 AM
seth90dx's Avatar
seth90dx
_____________________ ___
l l l l \
l l l l \
l l space l l side l
l__________l__________l l_____l
Well as you can see in my not so great description... There is a barier wetween my speaker inside my box! So I canot run them in series... And I do have them at 2 OHM's witch presents a 1 ohm load to my amp! I dont know how to wire them INDIVIDUALY at 4 ohms each? JL doesent have the specs for that
Old Sep 28, 2002 | 09:53 AM
b00gers's Avatar
b00gers
l l l l \
l l l l \
ok i have no idea what that drawing is.
you have the 2OHM per VC version. so if take a sub and wire it series, you will have 4OHM each sub....
from there take the pair and wire them in //, that will net you 2OHM for the pair.
so series on each sub, then // to the amp.
Old Sep 28, 2002 | 05:59 PM
seth90dx's Avatar
seth90dx
Well... I got them both rigged for 8 OHMS witch ends up as a 4 OHM load to the amp... Also when I pulled my subs there was browning on the edge of the voice coils? the part thats yellow and wavy... Is this from normal use or are they gettin burnt? cause they look burnt to me!
Old Sep 28, 2002 | 06:29 PM
b00gers's Avatar
b00gers
8OHMs each sub? you cant do that with the w3d2, only possible with the w3d4
what sub do you actually have?
sorry i dont know how a burnt sub looks.
Old Sep 28, 2002 | 08:42 PM
seth90dx's Avatar
seth90dx
Its the D4! The W3V2-D4! Its the new W3 ya know VERSION 2 V2
Old Sep 28, 2002 | 08:52 PM
SiClone's Avatar
SiClone
X-Moder8er
Jl has MANY wiring diagrams on their website: www.jlaudio.com under tutorials. You should really visit that site. It will help you understand how to wire your subs.
And you should not have been running your amp at 1 ohm. That could have fried your amp.
As for your subs, double check your wiring AGAIN before powering them up again. If they still distort when you crank it up too much, then sorry, because you fried the voice coils......:nono:
