power controlled by ignition switch
Old Aug 6, 2006 | 08:34 AM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
Default power controlled by ignition switch
how do i find a HOT wire controlled by the ignition switch?
Old Aug 6, 2006 | 10:54 PM
dmacaalay's Avatar
dmacaalay
Monkey See, Monkey Do!
multimeter?? what exactly are you trying to find??
Old Aug 7, 2006 | 12:00 AM
dleccord's Avatar
dleccord
gotta take out those panels where your knees go. should have a lot of wires under there and find a black/yellow wire in the ignition switch harness
Old Aug 7, 2006 | 07:41 AM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
well i need to hook a power something that can only come on when the ignition is switched. how do i splice into that wire? is that a good wire to splice into?
Old Aug 7, 2006 | 08:20 AM
b00gers's Avatar
b00gers
What is that something? And how exactly are you hooking it up? Relay? Or directly as a power source?
Old Aug 7, 2006 | 09:52 AM
dmacaalay's Avatar
dmacaalay
the ignition wire is the black/yellow wire coming from the ignition on most tegs.. may or may not be a good source to tap into depending on what you are hooking up... always a good idea to put a fuse inline..
Old Aug 7, 2006 | 10:51 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
I can't think of a single Honda that you can't tap switched 12V at the ignition on the white/black wire. Also, the cigarrette lighter is always an option.
Old Aug 7, 2006 | 06:46 PM
dleccord's Avatar
dleccord
no one said anything about the white/black wire. isnt white/black the starter wire?
Old Aug 8, 2006 | 05:25 AM
Shallow_Bay's Avatar
Shallow_Bay
teh accord guy
if you want an easy way, just tap into the interior fuse box. everything in there is only powered by ignition.
Old Aug 8, 2006 | 06:59 AM
flyromeo3's Avatar
flyromeo3
Do you have an aftermarket radio installed?
If you do just use the ignition wire from that. Follow it from the radio harness to where its connected on the OEM ignition wire right behind the radio.
