My Tweeter problem
Old May 1, 2006 | 07:48 PM
OblivionLord's Avatar
OblivionLord
Default My Tweeter problem
I have a 2 1 inch tweeters. The one located on my drivers side door panel near the window has an issue. For some reason it doesnt work when its cold inside the car but, it starts working the moment the inside of the car warms up. When it is a cold day outside I wait till the car warms up then turn on the heater. I then point the vent in the direction of the tweeter and put my hand to act as a duck. It immediately starts working. However the moment I take my hand away it lowers down to the point where its off. It eventually stays on like the other tweeter once the inside of the car is fully warmed up.
I'm thinking it has somthing to do with the "Ferro-Fluid" thats cooling the voice coil of the tweeter. Anyway is there something I can spray on it to prevent this or does it just need to be repaired?
This is the tweeter...
http://www.cardomain.com/item/KIC05KS25
Keep in mind that the passenger side tweeter works flawlessly therefore there is a problem with the driver side tweeter.
Old May 1, 2006 | 08:06 PM
Misa's Avatar
Misa
Pic Whore
looks like one of the leads in the tweeter is broken... and when its warmed up, it expands and completes the circuit... :dunno:
Old May 1, 2006 | 08:55 PM
OblivionLord
basicly I need to bring it into a reapir shop?
Old May 2, 2006 | 06:03 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
No, pull it out and check your wires for a solid and tight connection.
Old May 2, 2006 | 10:10 AM
Tankard's Avatar
Tankard
I've got some kicker tweeters(R19), which look like yours with the same little crossover things, and it did not take much to blow them. In other words, yours probably need replacing. I sent them off twice for new ones while still under warranty. I've still got them in my closet, new and never used because i knew i'd blow them again. I bought some NB.1 Power Acoustik tweeters for a fraction of the price, and have yet to blow them on the same amp.
Old May 2, 2006 | 09:33 PM
OblivionLord
The connection is as solid as can be.
Old May 2, 2006 | 10:40 PM
97teg's Avatar
97teg
You could try switching the left and right tweeter to see if the problem follows. If it does it sounds like its the tweeter since only one does it. I would return it.
