Need Help Installing AMP
Old May 3, 2006 | 04:59 PM
arun158's Avatar
arun158
Hey i have another question do you know if my stock radio has preout rca....in other words will they be able to hook it up easy
Old May 3, 2006 | 06:15 PM
Misa's Avatar
Misa
Pic Whore
the stock radio does not have any preout rcas... that what the line converters are for.
Old May 6, 2006 | 09:13 PM
b00gers's Avatar
b00gers
Well, i hooked the remote wire to the battery, and got it installed and when i turned it on the bass wasnt pounding like it should be....Im thinking the line out converter isnt doing well, so im gonna give up and let the pros install it, they can probaly install it straight to the factory radio and i will get the pounding at the max....
Thankz for the help bros, i might have failed but i have found a new home at honda-acura.net!!
Arun
Ummm. You probably already got it fixed, but why wasnt the bass "pounding"? Did you mess with the dials on the amp at al?
Old May 9, 2006 | 09:39 AM
Phateless's Avatar
Phateless
S2K compatible
Old May 9, 2006 | 09:43 AM
Phateless's Avatar
Phateless
S2K compatible
the line out converter takes the place of picture number 1, because you don't have those plugs on the back of your navi unit (which is stupid, because those units cost like $2000)
Old May 9, 2006 | 02:19 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
It's not there because the dealer doesn't want you adding aftermarket stuff to your car.
Old May 9, 2006 | 02:23 PM
Phateless's Avatar
Phateless
S2K compatible
that's wack. lol, honda has some of the biggest aftermarket support out there. how stupid is it for them to make it harder?
