laptop fan question
Old Sep 14, 2002 | 09:19 AM
j-speed racer's Avatar
j-speed racer
Default laptop fan question
i have a year old top model hewlett packard laptop. recently i've been having problems with it getting hot and shutting down. is this something thats just going to happen or does that mean the fan isnt working right or well enough? recently i've started proping it up a little and it still gets hot but doesnt shut down. any advice, suggestions? should i take it back to best buy to get checked out or is this a typical occurance. i was downloading songs alot of the times it happened.
thanks
Old Sep 14, 2002 | 07:12 PM
b00gers's Avatar
b00gers
if it has a warrenty, take it back.
i dont know too much about where the fans are in the laptop....does the shut down only happen when its hot?
Old Sep 14, 2002 | 07:45 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
you may have dust built up inside... hampering air flow... making it get too hot and shut down... if you can figure out how to get it apart... do so and blow the dust out with a can of air.
Old Sep 18, 2002 | 04:23 AM
igo4bmx's Avatar
igo4bmx
CockBlockerator
try getting a real fan and blow onto the laptop and see if that helps. if it does.. you may need to clean it..
laptops are usually easy to take apart... just take your time and get compressed air
Old Sep 18, 2002 | 05:06 PM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
**** testing it, thats why its doing it.
HPs clog with dust and shut down.
its abou t80 little screws, just take some time at work and pick it apart, get some compressed air and go to town. WD40 up the fans too.
Old Sep 19, 2002 | 05:35 PM
DVPGSR's Avatar
DVPGSR
I need sleep...
HP...since Carly Fiorina took over has gone to crap...but that is another story.
This is a common problem with laptops. There is a current lawsuit against I think Toshiba for this same problem. Bring it back to the place you bought it or contact HP online about the issue. In addition try placing a small book under the back edge of the laptop so that airflows underneath it. Also try not to keep it on wood as it does not conduct energy well and the heat builds up in the laptop.
Old Sep 19, 2002 | 05:37 PM
Fujiwara Takumi
It's my first day.
you know how many times i heard that EXACT quote? eerie.
Old Sep 19, 2002 | 05:39 PM
DVPGSR's Avatar
DVPGSR
I need sleep...
I will never buy another HP product...CF was bad enough then they had to go merge with Compaq. Bad idea.
Dude I'm sticking with Dell!
Old Sep 19, 2002 | 05:43 PM
Fujiwara Takumi
It's my first day.
I used to work for HP, good products.
most colours of any consumer printer on the market.
and compaq has always made GOOD, CHEAP products. I hope that rubs off on HP who makes GOOD, EXPENSIVE products.
Old Sep 19, 2002 | 05:46 PM
DVPGSR's Avatar
DVPGSR
I need sleep...
If you don't mind me asking fuji what did you do at HP?
HP makes some great products...particularily in printing which is all we use at work. CF was a bad choice from them, she is moving the company away from what it was. As for Compaq I have only heard horror stories from people that buy their products from the quality to the support. I hope that part of Compaq is left behind, unfortunately that may not be the case.
