Unlocking RSX radio when code fails?
Old Jan 23, 2006 | 08:56 PM
smokealot's Avatar
smokealot
Default code for radio
yo i have a 99 cl, when i hooked up my system i put the remote output to the fuse of my battery. then i hooked everything up, after relizing that, now i had to get the code for the radio because i triped it by unhooking the fuse. i tryed guessin it but you can only do that three times, then it locks up. YOU HAVE TO disconect the battery from your car. TOTALY so theres no power runnin to your shit.
if you still have to get your code, what i did is i went to the acura/honda dealership. NOT where i get my car from, just the dealer; showed him my serial# and waited like 2 days and the acura people sent him the code, then he gave it to me.
Old Nov 2, 2007 | 07:08 AM
crxsi88zc's Avatar
crxsi88zc
Has anyone had any luck with this i have the same problem and i can't get it to work!!!!!!
Old Nov 25, 2007 | 07:40 PM
flappy188's Avatar
flappy188
O.G. SON!
when entrering the code you have to hold the button in for like 5 seconds until you hear a chirp, which means it excepted each number when entering it, so if code is 54304 enter it like this 5hold button till chirp, 4 hold till chirp3 hold till chirp, 0 hold till chirp, 4 hold till chirp. then the code will work correctly. i bet you guys wernet holding the buttons in long enough.
Old Dec 9, 2007 | 06:31 PM
flyromeo3's Avatar
flyromeo3
x2
