sub
Old Dec 6, 2005 | 08:37 PM
sollivier's Avatar
sollivier
Default sub
i have this sub http://www.infinitysystems.com/caraudio/product.aspx?ProdId='REF1040W'&Ser=REF&Cat=SUB and am wondering how many watts i should use to power it. i only have one sub
Old Dec 6, 2005 | 09:33 PM
b00gers's Avatar
b00gers
Power Handling, RMS: 250 Watts
You want to feed it a nice 250-300 watts.
Old Dec 7, 2005 | 09:46 PM
sollivier's Avatar
sollivier
will it put out alot of deep bass with 250 to 300??
Old Dec 7, 2005 | 10:48 PM
b00gers's Avatar
b00gers
Thatll depend on the enclosure as well. I have a 10" in a ported box, with about 300 watts. It gets low enough for me.
I wouldnt expect a whole lot from that woofer. But then again, its all subjective
Old Dec 8, 2005 | 04:06 AM
Try2Live4God's Avatar
Try2Live4God
I don't mean to jack this thread, but I was wondering what sub and amp is recommended. I have a stock setup at the moment, but I wanted to add a lil' bit of bass. I do want a 10" sub. I don't need anything that will make me go deaf. Just something that adds a lil' bass that's crisp and clear.
Old Dec 8, 2005 | 07:13 AM
b00gers's Avatar
b00gers
Budget?
Old Dec 8, 2005 | 04:13 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
I have a Kenwood KSC-WD250 10" in my trunk and I have been nothing but impressed with it. Dual 1.5 ohm coils wired to .75 ohms, wired remote, speaker level inputs as well as RCA's. I too didn't want to wake the neighborhood, just wanted to have some solid bass.
Old Dec 8, 2005 | 05:30 PM
del sol's Avatar
del sol
thats the worst sub i seen in years, cleary buy 2 you dipweiner, if you only by one, you might as well try to stick it up your ass, if i was you go with roadrage, very rare only found in selected walmart stores, its capable of putting out a 1/2 watt.
Old Dec 8, 2005 | 05:33 PM
skip259's Avatar
skip259
go with a higher powered amp.
400 watts.
250 watts is underpowering the sub. the sub can handle 1000 watts peak. push the amp at 250 watts, and you run out of headroom.
Phoenix Gold 400.1 should do the job.
But if you're set on the 250 watt amp, then just get an sub-in-a-box by infinity. it's a class D block amp with a 10 inch sub box. all you do is hook up the power and the line feeds. The amp is in the box.
just my 2 cents.
Old Dec 8, 2005 | 06:20 PM
totalimmortal
MalleusMaleficarum
Are you talking to me Del Sol?
