RCAs and amp help
RCAs and amp help
I am hooking up a 2 channel amp to drive 2 pioneer subs. I have a panasonic deck with front and rear preout. The amp have 1 set input and 1 set output. Question is do I plug the RCAs to the front or rear preout? Thanks
Yea the problem with adding the sub amp to the front or rear output, I believe that your fading option will hindered. But I did read this on Panasonic's site...
"In addition, a non-fading, low impedance subwoofer output is available to make adding a dedicated subwoofer amplifier to your system easy."
I dont know what they mean by "is available", but using the non-fade preout is the way to go.
Originally Posted by castroltran
so is the rear the non fade preout?
