Audio newbie question, please help
Old Sep 9, 2002 | 08:49 PM
Mid9Joker's Avatar
Mid9Joker
Default Audio newbie question, please help
I need to know what kinda of box and amp for a sub with 500 watt RSM, 1000 watt max, i'm looking for something with plexiglass, um..also note that i'm on a tite budget.
Old Sep 9, 2002 | 08:58 PM
LjN_728's Avatar
LjN_728
Now wut kind of bass are u hoping to achieve? Personally i don't like plexi because bass tends to hit hard. Because i have 2 subs, i have a sealed enclosure. It gives a more rumble and loose bass. But anyone will tell u that it's best to hear it for yourself
Old Sep 9, 2002 | 09:03 PM
b00gers's Avatar
b00gers
12" IDQ or W3 mated with a JBL 300.1 or double each.
im not sure if JBL still made the powervalve amps...but i recommend this because ive had a similar setup for quite a while, and have no complaints...theres probably better...but thats my opinion.
Old Sep 9, 2002 | 11:28 PM
LjN_728's Avatar
LjN_728
wait a sec..do u have the amp and sub already? or u just looking for a sub with 500 RMS blah blah blah?
Old Sep 10, 2002 | 03:30 AM
Mid9Joker's Avatar
Mid9Joker
I only have the sub, no amp or box yet. I want somethign to sound good but also look good because it's going to be a custom trunk, like i already said my sub has 500 Watt RSM, max power is 1000Watt, how do i know what sub is right for it?
Old Sep 10, 2002 | 06:06 AM
b00gers's Avatar
b00gers
itll be nice to know what sub it is.
Old Sep 10, 2002 | 08:05 AM
smokedogg's Avatar
smokedogg
tell us what sub it is, how many voice coils, and if its 2ohm, 4ohm or other. then we can match up a decent amp w/ it for ya
Old Sep 10, 2002 | 11:31 AM
Mid9Joker's Avatar
Mid9Joker
here is the specs for it thanks in advance, i also need to know what kinda box.
*12" Dual Voice Coil Woofer
* Magnet: 160 oz. Double stacked Ferrite
* Frame: 5 spoke Die-cast aluminum basket
* Cone: Reinforced aluminum curvilinear
* Surround: Oversized buytl rubber
* Spider: 2 Flat ultra excursion
* Power handling: 500 watts RMS, 1,000 Watts max
* T Yoke: Industrial Chromed Hex bolt retained, Bumped and Vented
* Double damper magnetic motor assembly
* Cooling: Double Vented (T Yoke and Motor Side vents)
* Voice Coils: 4 Layer Dual 4 Ohm High Temperature black Aluminum
* Voice Coil Diameter: 2.2"
* Nominal impedance: 4 ohms / per coil
* DC resistance (Re): 3.2 ohms ea. coil
* Frequency range: 20 Hz-1.1 kHz
* Fs:30 Hz
* QTS:.526
* QES:.614
* QMS:7.698
* VAS:56L (1.98 cu. ft.)
* SD:.0491M
* SPL:90 dB 1W/1m
* Xmax:16mm
* Mounting Depth: 165 MM
* Mounting Hole Dia.:296 MM
* Net weight: 22lbs
Old Sep 10, 2002 | 07:22 PM
OneToughCivic's Avatar
OneToughCivic
dood just so you know it's RMS
Old Sep 19, 2002 | 07:10 PM
seth90dx's Avatar
seth90dx
It must be an EXPLODE or somethin cause dudes not tellin us who makes it! LOL!
