sub and amp
Old Oct 3, 2005 | 09:23 PM
sollivier's Avatar
sollivier
which wiring will give me the most bass? the independance for the subs are 4
Old Oct 4, 2005 | 08:22 AM
dave97LX's Avatar
dave97LX
is a guitar hero
This wiring site gives a graphical representation of the impedance (ohm) load that will be put on your amp with two 4-ohm SVC subs like the Infinity 1030W's you're interested in:
http://www.rockfordfosgate.com/rftec...2&image=Submit
You want to wire in parallel to put a 2-ohm load on the amp as long as it's stable at 2 ohms (which that RF amp is). That amp puts out 250 watts @ 2 ohms and that's going to be split between the two subs when you wire it in parallel. If you decide to look at more powerful amps look at the specs and make sure that each amp you look at is stable at 2 ohms if you plan to stick with those subs. Hope that helps.
Old Oct 4, 2005 | 10:08 AM
freecrx's Avatar
freecrx
if you run 2 of those subs 4 ohm single voice coil wired in parallel and you bridge the amp you will be at full power be giving the subs 1000 watts.
Old Oct 4, 2005 | 06:54 PM
sollivier's Avatar
sollivier
hey thanks alot dave97lx and freecrx this helped me out alot
Old Oct 5, 2005 | 03:20 AM
freecrx's Avatar
freecrx
no sweat man....
