amps
Old Sep 15, 2005 | 07:10 PM
b00gers's Avatar
b00gers
Originally Posted by delsol161
ever ran an alpine type r sub? or components? it's be a hellofalot more practical IMO to run two seperate amps.
I wouldnt go as far as saying that. If the amp can provide the power, I dont see what is wrong. I run my fronts and sub off of a single amp.
Old Sep 15, 2005 | 08:32 PM
97teg's Avatar
97teg
Yes i have and do run components. Ive even run the alpine type x's components. Plenty of systems run fine with a single 4 channel running the whole thing. Also as i said before yes if the sub needs a huge amount of power then a mono or two channel would be more practicle. He never said he was going to run a big power hungry sub. Many subs will work fine off 250-300 watts. I have run a 2 channel to my components and a 2 channel to my sub. Currently i run a two channel to my tweeters, a four channel to the mids and the other two channels are bridged to a sub. The result? A nice balanced system. No it wont blow the doors out but it gets plenty loud for daily driving and my tastes.
Old Sep 16, 2005 | 09:46 AM
chod's Avatar
chod
what amp company is good? if you get alpine speakers..does it matter if you get an alpine amp? or can you just get a sony amp or some other company amp
Old Sep 16, 2005 | 10:08 AM
b00gers's Avatar
b00gers
Brand doesnt matter. Just match it with whatever is best for you.
Old Sep 16, 2005 | 10:03 PM
97teg's Avatar
97teg
I wouldnt say that it doesnt matter. Typically in higher end amps you find better board layouts along with components that are over built and better able to handle heat. This means the amp will be more reliable in the long run. Some amps have good reps for reliability and power while some amps dont have a rep for failing. Its kinda like a bmw vs a hyndai. Both are cars but the bmw will tend to use better parts. They will both get you to work but its whatever youll be happy with. The only other thing is be ware of "peak power" this does not mean anything and manufactures that tout their peak power over rms are probably not very good. Sony tends to be one of these companies. They will have 500 WATTS!!!!!!! in big bold letters but in reality will only do maybe 250 or so. Also beware amps that want to distract you with shinny things or lots of lights. There are a few exceptions but in those cases youll just have to know. Youll probalby hear more of a difference in power then in the actual sound of the amp. Especically in a noise environment of a car. I hope that helps.
Old Sep 16, 2005 | 10:25 PM
b00gers's Avatar
b00gers
I was answering to his " if you get alpine speakers..does it matter if you get an alpine amp?"
Brand matching doesnt matter. Brands matter. h: My bad for not being clear.
Old Sep 17, 2005 | 01:17 AM
chod's Avatar
chod
whats some good amp companies?
Old Sep 17, 2005 | 05:39 AM
delsol161's Avatar
delsol161
audiobahn, alpine, rockford fosgate, i've heard a lot of good stuff about power acoustic amps. some legacy amps are pretty nice, juss ask around. i'm sure others have some good suggestions too.
