hu not working
Old Oct 1, 2005 | 09:05 PM
orbit77's Avatar
orbit77
umm don't touch them together, your grounding out the wires and poping fuses and if your unlucky your hitting a hot wire to one of your speaker leads. if you have a chance use a volt meter or test light and test to see if you have a good ground and good switch and constant power. go to installdr.com and double check your wiring just in case.
Old Oct 5, 2005 | 04:55 PM
97civicEXVTEC's Avatar
97civicEXVTEC
my wiring is all correct.. the cd eject motor was the only thing working on the radio.. i took off the faceplate and popped it back on and the eject motor stopped working too.. HELP!?
Old Oct 6, 2005 | 07:14 PM
orbit77's Avatar
orbit77
hmmm what hu do you have? you could also take it to best buy and have them do a bench test, if they're cool they'll do it for free it should take them a few seconds to hook it up. if you have a reset button i would try that also for some reason you might not be getting enough voltage thru your switch or constant power or a bad ground. if not than i would suggest the head unit has a bad cap inside.
