need a little help
Old Aug 30, 2005 | 10:10 AM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
Default need a little help
i recently installed my system; consisting of alpine type e 10" sub/ and a 1200watt(300rms) kenwood amp....
the system sounds great but theres just one thing i need to do.....
my license plate keeps rattling when a certain ammount of volume is given. Is there a way i can get rid of this rattle
Old Aug 30, 2005 | 10:28 AM
b00gers's Avatar
b00gers
The plate vibrates because it is moving and hitting the bumper. Put some padding between it. I've tried putting Dynamat behind the plates and it works well. Having a lic plate holder might also contribute to the noise.
Old Aug 30, 2005 | 11:50 AM
delsol161's Avatar
delsol161
dynamat actually does sell a licence plate kit...
Old Aug 30, 2005 | 12:13 PM
Ludemandan's Avatar
Ludemandan
Prelude tracktion
Start by removing your license plate frames. They're useless, and IMO the car looks cleaner without them.
Old Aug 30, 2005 | 05:09 PM
2legit2quit's Avatar
2legit2quit
You Big Dummy
Buy some of that adhesive weather stripping that goes in door jams. It's about a 1/2 inch thick. Put it on the back of the plate. Works pretty good.
Old Aug 30, 2005 | 05:34 PM
b00gers's Avatar
b00gers
Too expensive for what it is. You can spend MUCH less money and achieve the same result.
Old Aug 31, 2005 | 04:48 AM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
ah ok ty for the info i'll try removing the frame and see how it sounds..... then i'll prolly put some padding.
Old Aug 31, 2005 | 11:28 AM
delsol161's Avatar
delsol161
i did it the easy way. i ran the screws through small pieces of rubber tubing, bout quarter of an inch think. worked wonders.
Old Aug 31, 2005 | 01:05 PM
Misa's Avatar
Misa
Pic Whore
any kind of rubber would work. I used some rubber weather stripping and double sticky tape.
I needed to put some behind my plate and i only have the stock radio
Old Aug 31, 2005 | 01:24 PM
delsol161's Avatar
delsol161
yup. juss about anything that absorbs vibrations will work.
