Help with head unit installation
need some help with the power wires and the ground
on my aftermarket stereo it has
constant power
ignition power
ground
power antenna wire (which can be used for the remote for the amp right ?)
OEM unit has
constant power
ignition power
chassis ground
and another wire that runs to the fuse box (2nd ground ?)
now im wondering where do I plug my stereo ground, right to the chassis ground or to the wire that goes to the fuse box if that is a ground
constant power
ignition power
ground
OEM unit has
constant power
ignition power
chassis ground
If absolutely neccessary you can use the power antenna wire, but some units will turn off the antenna(i.e.-no power output) if you put in a CD, tape,etc. So your amp(s) would also cut off, I'm guessing you don't want that! As far as grounding the head unit, simply plugging in your antenna will ground it, if you are at the point of guessing which wires are which. Better to do the safer route(W/the ground) than plug up ONE wrong wire, smoke in 12v isn't your friend!
