Solo Baric l5 10"
Old Aug 10, 2005 | 10:11 AM
Macleod's Avatar
Macleod
Default Solo Baric l5 10"
i need a quick refresher. whats the diff between a 2ohm and a 4ohm sub and how they are wired?
Old Aug 10, 2005 | 11:53 AM
b00gers's Avatar
b00gers
That is the impedance rating for the sub. The difference has to do with the amp you will be using. Amps will put out different power ratings at different OHMs.
So in order to decide if you want the 4 OHM or the 2 OHM, you should know what amp you are going to use.
Old Aug 10, 2005 | 12:56 PM
Chizzy's Avatar
Chizzy
500w@4 ohms or 500w@2 ohms..
Is there a difference in the sound quality of the subs in this case?(assuming the sub and amp can handle 2 ohms)
Old Aug 10, 2005 | 03:15 PM
b00gers's Avatar
b00gers
Realistically, no. probably not to the average person.
Old Aug 11, 2005 | 04:21 AM
flyromeo3's Avatar
flyromeo3
no.
Old Aug 20, 2005 | 08:55 PM
Bmpn's Avatar
Bmpn
Audiophile
the only reason subs are made in different coil configurations is for wiring flexibility. it makes no difference other than that, none.
