need your 0.02
Old Jul 26, 2005 | 06:43 PM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
Default need your 0.02
im not sure which amp kit to get. The 4 gauge or 8 gauge. My amp is 1100 peak power i heard the 4 gauge kit is good for systems over 1000 watts. i need people's 2 cents. Also what wires do i use to connect the sub with the amp? the sub came with out any wiring, the only wires i have that are used for the sub are the ones connecting the sub to the box, the box has two plugs on the exterior so im assuming thats what i plug the amp into right? Will the amp come with the wires for it or will the amp kit come with them?
Old Jul 26, 2005 | 06:57 PM
gasper44's Avatar
gasper44
4 guage.
Old Jul 26, 2005 | 07:00 PM
b00gers's Avatar
b00gers
You can get amp kits that include EVERYTHING. What is the model of the amp. Judging the amps real power needs from its peak power numbers is not that realible. But yea, 15-20ft of 4 gauge for 1000 watts of continous power is about right.
Dont forget to include the length of the power wire when picking the gauge size. And speaker wires are used to connect the sub to the amp.
Old Jul 26, 2005 | 07:18 PM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
can they be any speaker wires? or specific type i posted the amp model in a other thread it shouldnt be too far down on the list
{edit} Kenwood KAC-8152D 1-Channel Amplifier thats the amp i have
Old Jul 26, 2005 | 07:22 PM
b00gers's Avatar
b00gers
Wire is wire. The difference in them is the quality of the jacket and the strands of wire. Better ones will have a slicker coating so you can install them easier and will be more flexible. But since this is only going from the amp to the sub, just get 3ft of 12 gauge speaker wire and youre good to go on that end.
As for the amp...post it again :happysad:
Old Jul 26, 2005 | 07:25 PM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
read my previous post i added the amp model and ty for the speaker wire info so 12 gauge will be good for the 750watts peak sub right?
Old Jul 26, 2005 | 07:26 PM
b00gers's Avatar
b00gers
You should be fine with 8 gauge. But if you can afford 4 gauge, that wouldnt hurt either. It will be a lot easier if you ever decide to get a bigger amp or add a 2nd one.
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
im gonna get a 4 gauge kit for 20 bucks i'll post the link when in finished play some CS:S lol
Old Jul 26, 2005 | 07:27 PM
b00gers's Avatar
b00gers
12 gauge is fine.
http://www.precisionautosound.net/wiregauge.html
Old Jul 26, 2005 | 07:32 PM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
well looks like i'll be ordering this one
http://www.etronics.com/product.asp?...re=&catid=5748
has every thing 20ft 4gauge, 3ft 4 gauge for grounding, 12 ft speaker wire, and everythin else. 20 bucks aint bad not to mention i live in NYC and i get it in 1 day
as for installing all my stuff should i go prefessional cuz i dont have much experience with this... it seems pretty easy and all but i dont wanna fuck it up... i have the extra money to spend on installation so i think i would prolly be better off doing that
