97 Civic Aftermarket radio tie ins.
Old Jul 18, 2005 | 06:19 AM
SmutWanter's Avatar
SmutWanter
"Made to Please"
Default 97 Civic Aftermarket radio tie ins.
Does anyone know of this problem occurring in 1997 Civics? If so, are there methods to solving this problem???
"Trouble Spots Consumer Guide(R) Vehicle History Report
Check for these possible problems when test-driving and inspecting this vehicle.
Audio system: Installing an aftermarket radio can result in loss of dome lights and keyless entry. Those two systems are tied into the Honda radio. (1997)"
Old Jul 18, 2005 | 03:16 PM
vikool's Avatar
vikool
98 Accord Coupe 5spd!
What most people do is to stash the factory radio behind/below newer one. There should be enough space there, you could try removing the faceplate if it doesnt fit.
And then, when you hook up your new one, use a T-harness to connect both radios to your existing plug. Crutchfield has the one below, and i'm sure there are others.
http://www.crutchfield.com/S-pkGL1qO...p?i=120701720T
Old Jul 23, 2005 | 01:16 AM
Brad's Avatar
Brad
wooo nascar!
you need a reverse harness.
basically you have to shove the stock head unit down into the console and connect the yellow red and black wires to the other harness.
