Firewall Gromet
Old May 10, 2005 | 06:53 PM
AccordEXV6's Avatar
AccordEXV6
Default Firewall Gromet
Does any one know where there is a pre drilled gromet in a 2003 Accord Coupe. I need to run to 1/0 ga. wires. Would like to see if there are anyy pre drilled holes. Thanks
Old May 10, 2005 | 08:05 PM
SkyLord's Avatar
SkyLord
is it auto or manual? there is almost always a gromet where the clutch would be if it is auto. if there isnt a gromet there is the clutch "plate" where you can drill through but make sure there is nothing on the other side if you do this. thats wut we do at work all the time. if it is manual you have to find the factory wires that run thru the firewall and try to cut a whole in that gromet. but 1/0 gauge is a big wire to run through a tight gromet like the factory ones tend to be so gl with that.
