Security Question
Old May 1, 2005 | 08:29 PM
PinkJDMIntegra's Avatar
PinkJDMIntegra
Default Security Question
Im investing alot of money into my car, and I dont really know where to go for a good security system, or any name brands, so if someone could help me out id appreciate it!
btw, is it at all possible to get a security system like that blows up if like someone just barely touches it? sorry im a noob when it comes to this stuff =p
Old May 1, 2005 | 09:38 PM
Sh22awndo's Avatar
Sh22awndo
Basically anything from DEI (Directed Electroinics). The own about every "good" alarm brand out there. Viper, Cliford, Avatal, Phython, Sidewinder, Hornet, & ect...I was an installer for audio shops for about 8 years, and have seen it all, they are the best. Stay away from anything you haven't heard of. And anything sold and installed in a Circuit City, Best Buy, or any other big retail store. Find a local car audio shop and see what the sell. Or better yet check out the dealer locator at:
http://www.directed.com
Old May 1, 2005 | 09:51 PM
PinkJDMIntegra
thanks!!!
Old May 1, 2005 | 10:03 PM
b00gers's Avatar
b00gers
Yea DEI bought out a lot of companies. I have a Clifford. I think you should just find a name brand alarm with the features you want. Then find a QUALITY installer. INSTALLATION IS KEY!
Old May 1, 2005 | 10:19 PM
v-teg01's Avatar
v-teg01
Candy
i jus talked to a friend and he mentioned something about secret buttons, lol throughout the car, pretty nifty
Old May 1, 2005 | 10:31 PM
Sh22awndo's Avatar
Sh22awndo
Here this Might help if you are planning to install it yourself ( or your friend). This will tell you where all the wires need are, and what color the are. Straight from DEI baby!
DIRECTWIRE™ WIRING INFORMATION - ACURA / INTEGRA / 2000 / Remote Start
[PRINT THIS PAGE]
12volts white + ignition harness
Starter black/white + ignition harness
Second Starter
Ignition black/yellow + ignition harness
Second Ignition
Third Ignition
Accessory yellow + ignition harness
Second Accessory
Keysense
Power Lock black/white - drivers kick panel
Notes: In the larger of two attached gray plugs in the lower kick near the firewall. If equipped with cruise control, the plugs are behind the module. To access, remove the lower bolt on the bracket holding the module and pull it up out of the way. The lock wires test only with the passenger lock and unlock switch.
Power Unlock black/red - drivers kick panel
Lock Motor white/red driver kick panel
Unlock Motor yellow/red motor in driver door
Parking Lights+ red/black grn plug above fusebox
Notes: Also a male blade terminal is available in fuse box.
Parking Lights- green/yellow factory alarm (if equipped)
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger lt. green/red - drivers kick panel
Looks like 14 awg wire but mostly insulation.
Dome Supervision use door trigger
Trunk/Hatch Pin green -
Notes: 12 pin blue plug on top center of fusebox.
Hood Pin yellow/red - drivers kick panel
Trunk/Hatch Release blue - at switch
Notes: Trunk release only works with the doors unlocked.
Power Sliding Door
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock
Tachometer blue distributor
Notes: Also found in a 16 pin white or gray plug to the left of the fusebox.
Wait to start
Brake Wire green/white + brake switch
Parking Brake
Horn Trigger gray or blu/grn - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: 556U or 555U
Notes: N/A
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this
Old May 2, 2005 | 04:52 PM
PinkJDMIntegra
thanks!
