Dynamit
Old Apr 26, 2005 | 09:31 PM
spilot's Avatar
spilot
Default Dynamat
how should i properly install it in the 7th gen. came with no instructions.
Old Apr 26, 2005 | 11:08 PM
b00gers's Avatar
b00gers
Where are you installing it?
But it is pretty simple. The purpose of Dynamat is to be used as a sound deadener. You want to put the Dynamat on metal to put some weight on it. THat will keep the sheet metal from vibrating.
Clean surface off very good, that way the adheasive will stick well. Then cut the appropriate sized sheet, and stick. It will help if you use a roller to getting get the glue on. But before you do any of that, tell us where you are planning to put the Dynamat.
Old Apr 26, 2005 | 11:23 PM
ihookitup4u's Avatar
ihookitup4u
clean, peal, stick
I know all that but i still dont know the recipe for ice.
Old Apr 27, 2005 | 09:14 AM
Gotti's Avatar
Gotti
The Don
i think he means where do u stick it, and he's prolly talking about his trunk
Old Apr 27, 2005 | 01:24 PM
spilot's Avatar
spilot
nm, got it figured out. should i go ahead and get some dynamat for the rears (especially since they're 6x9's ) or is it mainly used for the door speakers?
Old Apr 27, 2005 | 06:09 PM
Omniscient's Avatar
Omniscient
warm butter on toast
It's used to deaden trunk rattle and stop the trunk from flexing. Even with the matt, my trunk rattled a little still, the matt didn't even do much so I took it out because it looked tacky anyway. Just spend 20$ and get a liscence plate dynamat. It's deffinetly the most effective.
Old Apr 27, 2005 | 06:11 PM
dave97LX's Avatar
dave97LX
is a guitar hero
what's the point of $20 extra for the dynamat license plate kit? isnt it just a smaller plate-sized sheet of dynamat? if that's the case, if you've got an extra scrap just slap it on the back of the plate, that would do it
Old May 1, 2005 | 07:08 PM
Omniscient's Avatar
Omniscient
Wha..? I said spend 20$ for the liscence plate kit and it will eliminate 3/4th's the rattle. I didn't say buy the trunk kit and the other kit.
