Amp overkill?
Old Apr 26, 2005 | 05:58 AM
Default Amp overkill?
I'm interested in this guy right here ...
Alpine MRD-M605
Key features:
» mono subwoofer car amplifier
» 400 watts x 1 at 4 ohms (600 watts RMS x 1 at 2 ohms)
» Class D design
» internal, variable-speed cooling fan
» Bass Engine® features:
• low-pass digital filter, 30-200 Hz, with a selectable 12 or 24 dB/octave slope
• selectable subsonic filter (off, 15Hz, or 30 Hz with 24 dB/octave slope)
• Bass EQ (0-16 dB at 45 Hz)
» top-mounted digital control center with cover
» CEA-2006 Compliant
» optional remote level control
» preamp inputs and outputs
» extra-large terminals
» fuse rating: 30A x 2
» requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
» dimensions: 11-7/16"W x 2-7/16"H x 9"D
» warranty: 1 year
I need it to power one of these:
MBQuart DWE254 10in Sub
* Impedance: 2x4 Ohms
* Frequency Response: 25 – 300
* Sensitivity: 2,4 dB
* Power Range: 250 watts
* Crossover Freq: - Hz
* Crossover Slope: - dB/octave
overkill? too much power?
the only reason I ask is because I can get that amp for $240 to my door. It's the best bang for the buck. I found last year's Alpine at around 200W for $200. :eh:
Old Apr 26, 2005 | 07:21 AM
b00gers's Avatar
b00gers
That thing is going to be putting out 600 watts to a sub that is rated for 250 watts. More power is always good, but then there is just too much. h: But I think if you keep the gains down, you will be fine.
Old Apr 26, 2005 | 07:26 AM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
y dont you just get a more powerfull sub
Old Apr 26, 2005 | 07:28 AM
I found the this one really really cheap, so I picked it up. A single 12 is in the future plans, but not for a while.
Old Apr 26, 2005 | 07:31 AM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
check out alpine type s subs, they not too expensive and i think have a power rating of 900 watts
Old Apr 27, 2005 | 06:10 PM
Omniscient's Avatar
Omniscient
warm butter on toast
It's better to get low rms subs with high output, aka mtx thunder 4500.
Old Apr 27, 2005 | 07:47 PM
ihookitup4u's Avatar
ihookitup4u
i would just put the sub in a sealed box for sure and you otta be ok. More power more better!
