Stuck CDs in 2004 Accord
Hi, I have a 2004 accord ex with the 6 disc changer and the CD are stuck in the player. When I push eject, it just cycles through for a while, flashing 'ejecting'' but nothing happens. If I try to play one of the CDs that are in it I get the error message on the display. Anyone have any ideas or experience with this and how did you fix it? thanks in advance....
Are these "home made" CDs with labels? If so, sometimes they can get stuck because they are a little thick. This happened to me in my Lexus and I used a tweezer to grab and pull out the CD. Good luck.
stuck CDs
I use CD-Rs with labels all the time and so far - no problems at all (knocking on wood). And you guys really shouldn't diss Honda factory stereo that much. For the price you are paying they are pretty good - it's usually either Alpine or Panasonic (depending on the type of stock stereo and year) and judging by indepedent reviews they are decent. Of course they are not Harman-Kardon or Martin-Logan but then again you didn't buy a new BMW...
As for your problem I agree with the other guys - either try and use tweezers or go to the dealer - they will have it out in a matter of minutes.
I am unfamiliar with the newer 6 disc changers. Is it in the trunk or is it in the dash?
If it's a magazine loaded model that sits in the trunk or glovebox, you can ...
slide the cartridge door open
put your fingers on the magazine
wiggle the magazine up and down
and hit the eject button
hopefully the cd will catch and eject out.
to prevent this, take the body of a wooden pencil and rub it around the outter edge and inner core of the cd. do this a few times to file down the plastic imperfections from the pressed disc.
