Audio, Security, & Automotive LightingTroubleshoot wiring problems and get equipment suggestions all in one place. Now expanded to include Automotive Lighting
The non fader should be going to the rear channels on the amp (3&4) and then bidrge those two channels to the sub.
I will move the non-fader right now.
Originally Posted by 97teg
The rear rcas are the ones that should be empty. The rcas for the front should go to channel 1&2 on the amp. When you tried the sub out did you make sure it was turned on in the deck? If you move the front rcas to 3&4 do you get sound out of the sub?
Yea the sub gets a sound when the channels were plugged into the Rear preout. Let me run out right now. I have a feeling that moving the non fade to the rear channels is gonna do it.
No luck. I put Ch 3 and Ch4 to the non-fade preout. The rear speakers still dont play. When I get the chance I will power them from the amp to make sure they work.
