wiring in parallel
Old Apr 23, 2005 | 01:29 PM
jr22's Avatar
jr22
Default wiring in parallel
i am going to wire two subwoofers in parallel and i was wondering how to do it. do i hook up one subwoofer to the terminals of the other subwoofer and then the 2nd sub to the amp? or do i just run both subs to the same terminals at the amp?
Old Apr 23, 2005 | 05:05 PM
b00gers's Avatar
b00gers
Wiring a pair of subs in parallel just means that you take the + from sub1 and connect to the + of sub2, then run that to the + on the amp. Same for the -. How you do it is really up to you. It would be better NOT to run both subs to the same terminal just because that is messy and would require more wiring. Most subs will have more than one male terminal connected to the voicecoil. You can just use that to connect the two.
File Type: jpg
Old Apr 23, 2005 | 08:28 PM
jr22's Avatar
jr22
i am also going to bridge the amp so would it be the same?
Old Apr 23, 2005 | 08:47 PM
b00gers's Avatar
b00gers
If you are sure you want to run the 2 sub in parallel...yes. Only difference is that with the final + and - leads, you will use the + from channel 1 and - from channel 2 on the amp.
