fuse location ?
could someone tell me what the fuse location is
for the constant power lead to the radio
on the 99 civic ex?
I thought it was 28, but that only gets power when the switch is on.
thanks
on the 99 civic ex?
thanks
In ALL Hondas there are two radio fuses! One under the hood, and one in the fuse panel. If you are going to replace you factory head unit, find the 7.5 amp fuse under you hood and replace it with a 10-20 amp fuse.
Some do, It's just good to do it because 1 most people don't know about it and 2 most aftermakert head unit run off of a 15-20 amp.
If your car is pulling alot of power, EI multiple amps or electronics in your car, that 7.5 amp fuse will be the first thing to go.
I say just replace that dinky 7.5 with whatever size fuse is on the HU then add a few amps for the clock. I have a 15 in there right now. My 7.5 kept on popping.
yeah but most of the upper lines of head units need a pretty good source of power to operate correctlly. Like the Alpine A series of head units (example CDA-9833), they have an enternal V-drive amplifier built in, and require a little bit more power than lesser models
