got a prob
Old Apr 20, 2005 | 10:28 AM
importkustoms00's Avatar
importkustoms00
Korean DOOD
Default got a prob
ok i got 2 12 alpine type e's and some rather little swiss audio amp. i previously had 2 12 jl audio w0's and had no problems with my system but when i switched the subs i cant turn it up too loud or my amp will go into some protection mode. any suggestions?
Old Apr 20, 2005 | 10:47 AM
cobbcustomz's Avatar
cobbcustomz
sounds like the subs are too low of an ohm load and when you turn it up the amp is going into protect mode
Old Apr 20, 2005 | 11:00 AM
importkustoms00
Korean DOOD
so ok i dont kno too much about stuff like this. what can i do to fix the prob
Old Apr 20, 2005 | 11:27 AM
b00gers's Avatar
b00gers
Post the exact model of the amp and sub. And also how you got the subs wired together and how the amp and subs are wired together.
Old Apr 20, 2005 | 11:36 AM
importkustoms00
Korean DOOD
Alpine SWE-1241 (two of them) 4 ohm
Swiss Audio (SMR1502) 150 Watts A/B MOSFET Amplifier
Old Apr 20, 2005 | 11:42 AM
importkustoms00
Korean DOOD
its bridged wired in parallel
Old Apr 20, 2005 | 01:09 PM
DaNnYsEvEn's Avatar
DaNnYsEvEn
ThInK PiNk!
try unbrdging it. this also happend to my guy when he had his kenwood amp in....the tech said they cant be bridged...which i think is bs.. but yea try it...
Old Apr 20, 2005 | 08:20 PM
b00gers's Avatar
b00gers
Those subwoofers are 4 OHM SVC. The amp's spec is: 75 watts x 2 @ 4 ohms stereo...12O watts x 2 @ 2 ohms stereo...150 watts x 1 @ 4 ohms mono.
If you are bridging the amp, and wiring the subs in //, the amp is seeing a 2 OHM load mono. That is too low for the amp. You will have to unbridge it, and put 1 sub per channel.
Old Apr 25, 2005 | 08:51 PM
importkustoms00
Korean DOOD
yah i did it and yes it works but i nd a bigger amp any suggestions
i was thinkin a kenwood mono power
Old Apr 25, 2005 | 09:16 PM
b00gers's Avatar
b00gers
An Alpine Type E sub takes 50-250 watts RMS. :thinking: How much are you looking to spend.
